4890 Noise
1 Jan 2004
Walsall (UK)
Ok brought a new system yesterday and managed to install everythink ok, BUT when i try playing a game or do the vista performance check, i get a strange noise coming from my graph card under pressure, is this normal for this type of card or shud i contact ocuk and see what they say.
thx
btw i have a RADEON GD 4890 850M 1GB DDR5 DUAL DVI TC PCI-E
that sounds like coil whine nothing to worry about very common with gfx cards.
if you get this sound when playing games enable vsync and the noise should go away
Mmmm not sure what to do, as the noise is annoying and tbh alittle scared incase the card screws up and if im honest a card shouldnt make strange noises, but shud i contact ocuk or just leave it mmmmm.
