4890 power connectors
6 Sep 2009
I am building my first PC, here is my problem.
The graphic's card needs two six pin power connectors but i can only find one six pin connector in the power supply loom.(OCZ StealthXStream 500w ) how do i solve this problem?
Thanks, Noel.
Only connestors with the card were, one for the old style monitor connection and a yellow video connector.
Can that 4 pin to 6 pin adapter be bought at the likes of PC world?
I doubt PC World would have them, you might need to check for a local PC shop or maybe ******s. Otherwise you'll find it everywhere online if you're in no rush for it.
I doubt it, the best idea would be to purchase from eBay with 1st Class post, you should hopefully get it Tuesday then.
