Hi everyone, thanks in advance for any help/advice.
My system is:
4930k Currently at 4.5ghz
Asus Rampage Extreme IV
2 x powercolor PCS+ 290x
16GB (2x8GB) Vengence black 1833mhz
Superflower 1300+ Leadex
Ok, so basically im trying to overclock my cpu. I have it at 4.5ghz with 8Packs settings from his guide and is stable. My Vcore is currently set to +0.040 which brings me to 1.365 under load. Im very new to offset so don't actually know wether i've got it right but thats the first number i hit when it becomes stable.
Now, after 4.5ghz its like i hit a wall. even with vcore set to 1.4+ I cant get past 4.5.
Another problem I'm having is tightening my RAM, I cant even change the command rate with out my PC failing to boot.
I hope I've posted enough info.... for now any way
Thanks
My system is:
Thanks
