4GB of memoray & 2x GTX 280 1GB`s in SLI - How much memory will XP Pro 32-bit see?
It won`t be wasted as for really high end stuff, i`ll be using vista anyways, but there's no point im me Installing my XP as well in dual boot, when it may only see less than 2GB.
Why would you even want xp. I'm not understanding. It will deff see less than 2GB. The only thing is it might not be a lot.
guys its ok, if i don`t like the amount of system memory XP Pro 32-bit sees when finally getting my system running next year, then i`ll just abandon it and only use Vista. Thank you all for the helpful responses on this matter;)
so does this mean that if you installed one of the new 4gb quadro cards you'd see no ram at all :p
Heh, I asked a very similar question yesterday: If a system had four 1GB cards in quad-sli, would the system be unable to access system memory at all?
Who's got pots of money and is willing to test this? Hmm, or maybe who do we know that runs a computer shop online who can fiddle about with builds?
(Obviously this is just idle curiosity - and it only applies to 32-bit systems.)
Since i`ll be using Vista for SLI gaming anyways, if i disabled one of the graphics cards in XP, would the os then see more system memory?
