If your gaming at 1080P then a single card should be more than future proof for years to come even on the poorest console ports which could be using around 6GB of memory:
980 is faster until you exceed its 4GB VRAM limit.
Games are using more than 4GB in current games, even at 1080P, 1440P upto 6GB usage is possible and 4k it is nearly possible to use upto 8GB.
This is today, who know what the case will be in 2-3yrs.![]()
It is not that simple though, and you're forgetting that the 290X 8GB as a single card simply does not have the GPU grunt to utilise all that VRAM. You need x2 of them Crossfire for that. If this weren't the case, then sure, 8GB card all day long, but you're kidding yourself if you think simply getting a card with a load of VRAM will cover you... and for years? Come on, let's get real. It's no different to an old GTX 670 4GB... more usable VRAM than a 970, but can it handle modern games as well... errr, no, obviously not.
Have 32GB so will do me for a long time
With the way that games are going, how long do you think it will take until 4GB is not enough to play games on max settings
i'm quite tempted to leave mine and upgrade to a 290x but is it worth it?
