Hi, i bought the 32" 4k monitor Samsung LU32H850UMUXEN
However, i've set everything up and it's stuck at 30hz. There's no option for 60hz at 4k resolution.
I have a gtx 780 and i've done some research and i've come to the conclusion that my GPU does support 4k resolution at 60hz. Now i will be posting some pictures since the only way i can get my monitor to turn on is via the HDMI 1 cable. I have a display port1.2 cable but it doesn't seem to work or i'm not sure what's up with it. I've successfully connected all 3 wires to the back of my monitor, the issue is connecting them to the back of my PC.
The HDMI Cable connects just fine to the back of my PC, so does the USB wire into a regular usb slot at the back. However the display port cable doesn't fit anywhere or go into anything at the back, so what i did was, i found a small attachment that was in the box full of wires and it seems the display port cable does go into this attacher, i then attached that to a small port like you will see in the picture below. I will circle where i've inputted everything. Please help me, i have no idea what's wrong but i can't even get 4k to work on my 4k monitor at 60hz. Warning: My case is very dirty, i haven't cleaned it in a long time, try and ignore it, i know i need to clean it etc, don't ask me how long it has been! i will be buying one of those air sprayers i got last time and cleaning it in a day, but before then i'd really like to see 4k on my monitor like advertised.
These two pictures are of the back of the monitor
as you can see all fit in correctly which is expected as they came with the monitor. (I've not included the img code because pictures are too big)
https://i.imgur.com/bHQFZSS.jpg
https://i.imgur.com/zljB4Xu.jpg
As you can see the display port in the middle and hdmi 1 on the left.
Now the hdmi connects fine to a port at the back of my computer, the display port does not so i found this connector in the box that had all the wires in it and it seems to fit in this connector. After it fits, i connect it to a small little port at the back of my pc right under the usb section.
https://i.imgur.com/1h6Hend.jpg
Warning, very dirty case! https://i.imgur.com/KehotW9.jpg
I've outlined where i then connect my display port after connecting it to the adaptor like seen in the above picture. Right below the usb section there's that small port thing you can see in the picture i have arrow pointing to and that's where it seems to fit/go in. However even when i have all 3 connected into back of pc + monitor, i'm still only getting 30hz at 4k and not 60hz. Can someone explain what is wrong? i've tried searching but i can't seem to find an answer, Thank you very much for any help!
