LG B6 OLED
Ultra HD Movies with HDR and HDR games look really good.
Also cannot get anything to run full-screen at 60hz via the PC, it keeps defaulting back to 30hz, So I'm forced to run games in windowed mode.
Alas PS4 stuff looks bang on, GT Sport is glorious, shame about the PC side, I'm all ears if anyone has any ideas on that.
TV has no display port but can do 60hz 4k over HDMI on two of it's 3 ports. 3840x2160 on the desktop @ 60hz works fine. Just when you try to fullscreen a game it will drop down to 30hz at the same res.HI,
What resolution are you using on pc and what connection type, iirc if the resolution is set to high then you need to connect via display port to get 60hz.
Unlikely this early into ownership. Check back with people in 18-24 months time.I bet yeah. Any issues with image retention at all?
HDR issues in WW2 for me with an LG 2016 VA panel. Intermittently the picture will just black out or flicker green.
This issue doesn't occur with HDR turned off, when it happens if I turn the TV off and back on the HDMI handshake seems to cure itself and all is okay again.
Just something to be wary of with HDR, I don't think it's particularly without it's problems.
Same as you OP. The OLED's look great but not great enough to warrant the extra for me personally. Maybe when the issues are ironed out I'll get one in 3+ years.
Nothing on my B6 and it’s in constant use with all sorts of content and abused by 3 kids too.
It’s like everything tbh a few cases and it’s a bigger problem than it actually is.
