4k stutter and judder
26 Aug 2018
Hello,
As subject implies, I suffer judder and stutter on 4k content
Hisense 65" 4k Television (E65K5510UWTS)
Denon 4k Amp (AVR-X540BT)
PC (i7 7700, Intel HD 630, SSD for O/S, 2TB HDD and a couple of USB HDDs,32gb RAM)
5k Player, VLC, HPC, MPC, Cyberlink etc
Judder amounts differ from one software player to another.
It's not the amp, as I took that out the "loop" and issue remains.
Is it as simple as the onboard IntelHD630 isn't upto the job and I need a dedicated graphics card?
Regards
Chris
Hello,
Regards
Chris
lol yes definitely, no where near close to upto the job, I just about manage to run 4K with an ASUS strix GTX1070 8gb OC card, but everyone will recommend you get a 1080ti.
Seriously. £600 on a graphics card, just to enable 4k playback!?
yup, unfortunately, newer technology is always more expensive, 4K as everyone knows is 4 times the pixels of 1080p and I wouldn't even use onboard graphics to game etc on that.
You don't have to buy a 1080, like I said my 1070 runs it fine, and can be picked up for about £450, but if you can hold off, prices are slowly coming down, its all the miners that thrashed prices up sky high, you could also look at AMD's side of things and get something like an 580.
My card https://www.overclockers.co.uk/asus...ddr5-pci-express-graphics-card-gx-403-as.html
RX580 https://www.overclockers.co.uk/pc-components/graphics-cards/amd/radeon-rx-580
Hello,
Regards
Chris
Can you not just use the TV to playback these titles via network or usb?
A GT 1030 will solve your 4k (non HDR) playback issues, It's the quick and easy fix if you want playback via your pc. Due to certification issues, a GT 1030 cannot playback Netflix 4k HDR. Your TV's Netflix app however should.
If you want to stream 4k HDR (or decode 4k HDR media) up the budget a little and pick a GTX 1050 or GTX 1050ti
If the TV has a plex app you could use the system as a plex server and use the tv as a plex client and play it all back through the tv. (this is just an example, there are many ways you can go about this)
These guy's are assuming you game on it and not just using it for 4k media duties.
The TV will play direct via USB if I move the usb HD to the TV, bit why should I? Also, I want the HD audio soundtrack. Wouldn’t I lose that, as it needs HDMI?
