Why do you want 21:9? You shouldn't have an issue with the 16:9 res's like 2560x1440.
Because 21.9 is vastly better than 16.9 for immersiveness imo. After having used 21.9 for 4-5 years, 16.9 feels incredibly squashed, even on a 55" screen.
Fair enough, I'm not sure if I'd want to play with black bars top & bottom but I suppose when on a 55" screen the used real estate's as big or bigger than a 34" ultrawide. If the Field of view can be tweaked on some of the games you play that might help.Because 21.9 is vastly better than 16.9 for immersiveness imo. After having used 21.9 for 4-5 years, 16.9 feels incredibly squashed, even on a 55" screen.
It sounds like you are using the 3rd party utility to run the desktop at the 21:9 res rather than making it save a permanent desktop res option selectable within windows and therefore games.
Yup on 55" and OLED, the black bars are a non issue, it is just like watching a 21.9 film on a 16.9 display.
Crappy pic but it gives you an idea:![]()
And increasing FOV on 16.9 won't help, you just can't achieve the same effect as 21.9 without adding fish eye![]()
It does look good.
I've never been keen on widening the FOV either but I thought I'd mention it as some people like it. A lot of Stalker modders seem to like it.
Thanks for that. In fairness, I have used my PC on my OLED for about 3 hours max and then took the PC back upstairs. IQ was excellent though and very happy with that and colours were so deep.Hey Gregster,
I find most the lag when playing on tv comes from vsync and locking the frames to 60.
When I play overwatch and stuff I vsync off and run at 200fps it's pretty much instant then.
Even though my tv has very low input lag vsync on 60fps is unplayable for me on first person shooters.
Had the same with destiny 2 vsync on was pretty much unplayble with that off maxed out I was getting 90fps and still pretty laggy but turned couple of things down like depth of field 1 notch and shadows down a notch and started getting 200 fps and felt very nice.
shoulda spent 1500 quid on a new pc
nice tv tho![]()
Ignore me, looking at the wrong bit
My advice - get an Nvidia 1070Ti...
Why are you trying to use 21:9 on a 16:9 screen though?
Watch that burn in.
