Hi Guys and Gals,
I'm looking to upgrade to a 4k monitor soon and I would like recommendations on a GPU upgrade if necessary.
Currently I game at 1080p but I am finding myself more inclined toward 4k. It is something I really want to do.
At the moment I am using a 980GTX Palit Superclocked. I am running it a default settings and a slightly reduced fan profile. I am willing to SLI.
PSU wattage isn't an issue and space aren't an issue either (900D).
Ideally I will add the gpu/s to my waterloop so I'll need a new radiator and a couple more fans but mainly I need advice on what could give me high settings at 4k.
I play a total range of games so aim for hardest hitters on FPS please.
If you have a 4k monitor recommendation then I'm also happy to listen
No budget set at this stage, however availability in Egypt can be a pain so most likely I will end up either importing or collecting from the UK soon.
________________________________________
samsung ringtones , free ringtones , loud ringtones
