4P build problem.
Sorry Dyslexic can be troublesome
TPC
should be the same on mint as ubuntu ...(should)
and it wont "push" your system past your current over clock ... it will just Lock
the processor P-State, so it never changes to something less than, Turbo boost
Full load
Think I have it installed....
have this....on the nodes, all saying the same thing.
-- Node: 3 Core 7
core 7 pstate 0 (pb0) - En:1 VID:37 FID:10 DID:0.00 Freq:2600 VCore:1.0875
core 7 pstate 1 (pb1) - En:1 VID:37 FID:10 DID:0.00 Freq:2600 VCore:1.0875
core 7 pstate 2 (p0) - En:1 VID:41 FID:7 DID:0.00 Freq:2300 VCore:1.0375
core 7 pstate 3 (p1) - En:1 VID:43 FID:5 DID:0.00 Freq:2100 VCore:1.0125
core 7 pstate 4 (p2) - En:1 VID:45 FID:2 DID:0.00 Freq:1800 VCore:0.9875
core 7 pstate 5 (p3) - En:1 VID:46 FID:0 DID:0.00 Freq:1600 VCore:0.9750
core 7 pstate 6 (p4) - En:1 VID:48 FID:12 DID:1.00 Freq:1400 VCore:0.9500
-- Node: 4 Core 0
core 0 pstate 0 (pb0) - En:1 VID:35 FID:10 DID:0.00 Freq:2600 VCore:1.1125
core 0 pstate 1 (pb1) - En:1 VID:35 FID:10 DID:0.00 Freq:2600 VCore:1.1125
core 0 pstate 2 (p0) - En:1 VID:39 FID:7 DID:0.00 Freq:2300 VCore:1.0625
core 0 pstate 3 (p1) - En:1 VID:42 FID:5 DID:0.00 Freq:2100 VCore:1.0250
core 0 pstate 4 (p2) - En:1 VID:44 FID:2 DID:0.00 Freq:1800 VCore:1.0000
core 0 pstate 5 (p3) - En:1 VID:46 FID:0 DID:0.00 Freq:1600 VCore:0.9750
core 0 pstate 6 (p4) - En:1 VID:48 FID:12 DID:1.00 Freq:1400 VCore:0.9500
--- Node 0:
Processor Maximum PState: 1
Processor Startup PState: 6
Processor Maximum Operating Frequency: 3200 MHz
Minimum allowed VID: 123 (0.013v) - Maximum allowed VID 19 (1.312v)
Processor AltVID: 50 (0.925v)
not sure what to do now.
if you have it installed correctly
you need to start it
open a terminal window
and type in the command
sudo tpc -psmax 1
seeing you are overclocking
you should also have OCNG tools installed ...
so u can do
sudo clockspeed
not sure this will verify anything as i dont overclock currently
but i do have the OCNG tools installed
even though i didnt flash the bios
what i do is a before and after
sudo clockspeed
sudo -psmax 1
sudo clockspeed
and that shows the difference
