4S scratched screen
4 Feb 2003
West Midlands
My own fault, never use a case etc.
It fell off the sofa last night during some sexy time with Mrs Nathan then I proceeded to stand on it and slide it with my feet across the oak floor.
This has resulted in 2 significant scratches across the screen :(
Can it be polished out? Perhaps Jeweller's rouge?
Failing that, how much does apple charge for a new screen?
no, not yet. I have not tried anything, just tried forgetting it was there however it did not work haha.
Toothpaste may work on glass I suppose
Any abrasive compound as suggested will take the anti-reflection/anti-fingerprint coating off and it will look worse than just being scratched.
I believe you can buy the replacement glass with digitizer for around £40, maybe less (you don't need to replace the screen!).
