5.1 only producing stereo ?
Permabanned
18 Oct 2002
Derbyshire
I have onboard optical and co-axial out on my shuttle but using either an optical or coaxial digital cable it throws all channels through the left and right front channels
all the sound is output it just isnt sent to seperate speakers
I have checked all the settings and it is set to 5.1.
How do i get it to split the channels ?
Thanks James
Unless the onboard sound does Dolby Digital Live (unlikely), that's all you're going to get using digital outputs. You'll have to use the analogue outputs to get 5.1.
