- 27 Jan 2011
- London
I bought a 5.1 setup of AKAPI S210 – 5.1 speakers
It came without a sub
do i need one?
do i need one?
I think he means Takapi, which I found a 5.1 system. Akapi came up with nothing.. If it is the one I have been looking at, then it has slim tower speakers. The amplifier is in the subwoofer, so everything connects to that. Without that subwoofer, nothing much is going to happen. Get on to the person you bought it from.
THIS LISTING IS ONLY FOR 2 FRONT 2 REAR AND 1 CENTRE SPEAKERS & SPEAKER CABLE ONLY SUBWOOFER IS NOT INCLUDED IN THIS LISTING.
OP, do you have something already that you were going to connect these speakers too?
your being jassive batty's ?
a wahhh??You will need an amplifier 1st. You can't just connect passive speakers to a sound card.
That's fair enough, apologies for any offence.
Yes, those towers will produce no lower frequencies. Not only are they incapable, because they have no drivers that are large enough, but in a 5.1 setup, all low frequencies are sent to the subwoofer. Only way you can get away with no subwoofer in a 5.1 setup, is if the front speakers have fairly big woofers.
damn... I guess I will have to just return my order.That's no use. You can only use that with the correct DVD player system it was designed for.
I'm sorry to say, but you have bought something without really understanding what you have bought. The fact you didn't know what an amplifier was, when I mentioned it, shows this.
I don't wish to be mean, but you should really understand what you are buying, before you buy it. This applies to many people though, probably too many. Many times I've seen people buy passive speakers, then expect them to connect direct to a sound card.
You would either have to buy a 2nd hand AV receiver/amplifier, or a new one. The only other option is to find a similar subwoofer to the one you link. That has a 5.1 amplifier built in, but it would need to be indepedant, and not need a DVD player/unit in order to function. Had you known all this before hand, you could have bought something which came with the subwoofer and amplifier, which ultimately, would have been cheaper.
Always understand what you are buying, before you buy it. This applies to everyone.
yeah buy a sub and amp, but make sure the sub will work with the amp, and see if the sub is passive or active
