Of course, but in reality there's no need. Switching to 4 cylinder mode is apparently imperceptible and instant (and I trust that it is), but I just think the whole existence of the 4 cylinder mode in non-economy run mentality is compromised by low output.You can probably switch it off if you didn't want to do it.
It's an AMG Mercedes-Benz; these have cost a lot to fix for a very long time. The invoice for a 500 HP 55 AMG V8 'Hammer' engine alone is in excess of £40,000... before labour.It strikes me as something that will cost a lot to fix when it breaks...
It's an AMG engine, it's not "not" going to sound like an AMG engine, 4cylinders running or 8.
They can use active acoustics to create much of the AMG noise. Bear in mind that as soon as you request more than 40% of the torque, go over 3600 RPM or try to use more than 30% of the power all 8 cylinders will be firing. AMGs are tuned to be reasonably calm under light loads as they aren't out-and-out racing machines, so I suspect this will retain 99% if not 100% of the AMG character by sounding awesome when used but offering just a light rumbly rasp when milling about.Just look at any Youtube video of the C63 AMG where the bonnet is up with the engine running, it doesn't exactly sound like a 6.2l V8, but point the mic at the back....
Is it?
The balancer shaft system is the complicated and heavy side of adding it. Turning of 4 cylinder is pretty bread and butter. Honda also did VCM, Variable Cylinder Management.
You still have the extra friction of the cylinders so its not the same as just a 4 pot.
The sound vents and channels the exhaust follows through to the back isn't going to change is it. The bulk of the noise from an AMG is in the exhaust note to begin with.
For the first time AMG is using a sports exhaust system featuring an exhaust flap on each side. This technology resolves the age-old conflict of an emotional sound during spirited driving and a more discreet engine note at low speed operation.
Each of the two rear silencers has a flap which is variably activated on a logic-controlled basis depending on the driver’s accelerator input and the engine speed. At low loads and engine speeds below 2,000 rpm the flaps remain closed. This causes the exhaust gases to cover a longer distance and flow through an additional damping element, so that the engine sound is pleasantly subdued and irritating frequencies are effectively suppressed. When the driver accelerates, the flaps open at an angle of 15, then 30 and up to 50 degrees so that some of the exhaust gases cover a shorter distance. This produces a sonorous engine note. Under full load at higher engine speeds, in performance-oriented eight-cylinder operation, both flaps are fully opened so that the occupants are able to enjoy the muscular sound typical of an AMG V8.
The twin-pipe AMG sports exhaust system with two chromed twin tailpipes on each side has a diameter of 65 millimeters from the manifolds to the pre-silencer. The diameter is reduced to 60 millimeters from the pre-silencer to the rear silencers.
A V8 burble is thanks to the frequency of combustion events..... you just halved that going to a 4 cylinder, now from when I checked todays 4 pots can not be made to sound like a V8 by changing the exhaust system.
There is the fact that the remaining cylinders are still pumping air so whilst there isn't as much air or at the same temperatures, there is still air going down the exhaust pipe from those cylinders.
