Man of Honour
- 17 Feb 2003
- Chelmsford
Just wondered if anyone has any news when we might expect to see a range of waterblocks appear for the 5* series?
Or just buy universal blocks that cost less, provide better GPU core cooling, are less restrictive and won't have to be replaced everytime you upgrade the card.
5. Universal blocks are only universal until somebody changes the hole diameter and it doesn't fit your new card anymore (although manufacturers are now better about this than before but I wouldn't be surprised if the fermi is different to the gtx 2xx series)
Not quite true though, have I had both and they have the following disadvantages:
1. Although costing less you still have to buy an armfull of ram and vrm heatsinks and the problems associated with getting them to stick.
2.Occasionally, if the airflow is not good enough in your case and clocking to the extreme, you need to add a fan to cool the heatsinks on the vrm (which kind of removes one advantage of watercooling). I had to do this with my 4870.
3. Full blocks properly cool the ram and vrm and I have always found that this gives a higher maximum overclock than just the vga block method. Also I find that they cool the core better than most stand alone gpu only coolers, not the other way round.
4. They are neater and look nicer.![]()
