So... It's been a while. Haven't posted on these forums in ages. Thought I'd start out by asking some advice.
I have (had) 2 Lacie 250GB External hard drives. I say had, as one of the drives suffered unrecoverable mechanical failure after just 14 months of use. Needless to say, I was a little peaved to lose 250GB of data. Classic response from Lacie of course - we recommend you backup all your data - which would be handy if this wasn't the backup drive! Anyways, rant over.
I now have an external enclosure begging for a new disk, and after deliberation, I have come to the conclusion that it is sensible for me to look at 500GB disks. Yes I will fill it...
Basically, what should I be looking at. I'm increibly tempted by the Western Digital MyBook External drive (as the auto-switch-off is a nice feature), however the one year warranty doesn't exactly inspire me. If I look at internal drives (IDE only for the enclosure), I am fairly limited in choice. The cheapest at OcUK is the Hitachi drive, but I have never used them before. Are they any good?
To put this in perspective: the drive that died was a Seagate. This is now the third Seagate drive I have had fail on me (OK, over a number of years, but all failures have been Seagate drives), therefore I am disinclined to look at their options. People seem to be having issues with Maxtor drives (although the 4 I am running have been goin in Raid 0 for 3 years without even wincing).
Thanks for your time people.
