500gb not recognised
in windows xp all you need to do is go Start>Control Panel>Performance and Maintenance>Administrative Tools>Computer Management and click on disk management. you should see your drive. you can then right click on it and select format
Hi, i have just built my new pc with a 500gb HD, installed XP but its only showing as a 127gb HD. Any ideas?:(
You need SP1 (preferably SP2) slipstreamed onto the install CD to enable 48bit LBA support for large disks.
There are various options going forward. A second partition using the remaining space; extending the existing partition with Partition Magic or Gparted; or reinstall with an SP2 CD.
Thanks for the replies guys.
I tried slipstreaming sp2 but it wouldnt go with the Dell version of XP i have.
I now have a XP disk with SP2 that i have borrowed, hopefully this will work.
WOW thats the long way round, just right click my computer then go to manage.
