Have a look at RTINGS reviews on monitors and around issues with OLED VRR (variable refresh rate) flicker, text clarity screen burn.
That soon put me off a bit and then spent almost £500 on travel and accomodation for a friends stag do instead
Sticking with my 100Hz IPS 34" Gsync screen until OLED have something like a 165Hz+ Gsync ultimate that doesnt have issues.
I did consider an Alienware AW3423DW. OLED, 34" Gysnc ultimate, 175Hz.
However its now 2+ years old, so feel something will come along soon and be much improved. That being said, im sure if I saw the aw3423dw in person and played a couple of games id buy it there and then!
Dell Alienware AW3423DW vs Dell Alienware AW3423DWF Side-by-Side Monitor Comparison
The Dell Alienware AW3423DWF is a newer model similar to the Dell Alienware AW3423DW. They use the same QD-OLED panel type, so the picture quality is nearly the same between each, except that the AW3423DWF doesn't get as bright in HDR. The main difference comes with their VRR support, as the...www.rtings.com
Stop it, you're making me want to use my aw34dw instead of the aw32 now!!!
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
