5090 FE PCIe Issue Need Help!
19 Feb 2025
London / Bangkok
Hi guys. I have an issue, possibly with my 5090 FE. The issue:
- I am running a water cooled system, the 5090 FE is in a waterblock
- I keep getting code 99 on my x870e Nova as it’s booting. It indicates a Super IO initialization error with something in the PC.
- I’ve unplugged every USB device and slowly added them back on but narrowed it down to the GPU.
- It boots fine if the GPU is unplugged and I boot on integrated graphics
- I took my card out cleaned the pcie connector and slot. Put it back in and worked for hours, I gamed and worked no issues. Powered down, tried powering up again and it went back to getting stuck at code 99.
- It is on a riser cable this might be the issue. I forced Gen4 didn’t make a difference.
- It’s weird, every 10 to 20 boots, 1 boot will get me to desktop and PC will work fine through the GPU
- In Minidump files they showed 2 errors such as: 0x116 VIDEO_TDR_FAILURE error and 0x50 PAGE_FAULT_IN_NONPAGED_AREA
Only possible remaining solutions I can think of troubleshooting (waiting for soft tubing to arrive to sort as running acrylic tubes):
- Plug GPU directly in the PCIe slot: riser cable broken if it works consistently (soft tubes needed, I don’t to bend another acrylic tube for a while lol)
- If top did not then plug riser into lower PCIe slot to check if top one is busted
- Ask NVIDIA if I can buy a replacement PCIe connector, that may be the bit that is failing
- If solution above worked or didn’t work a new motherboard and verify that motherboard itself was not compromised PCIe (although I feel this one is highly unlikely)
- Something gone wrong with my GPU, RMA with Nvidia (but it does not explain that it can work for hours and then not initialise properly on following boot)
Sorry if this was a long one, but don’t want to spend more if I can resolve. If any has had any issue like this, some tips would help :)
I would rule out the pcie riser before anything else. Seems like the most logical culprit.
Why not just drain the loop, disconnect the pump, remove the riser, connect the GPU directly to the pcie slot and see if it boots?
You mean as in check if it posts without attaching it or CPU to any form of tubing?
What PCIE gen are you using in the BIOS? A quick 'fix' would be to set PCI-E 4.0 or 3.0, since it is common with risers that they don't like newer PCI-E gens. This would be easy to test compared to the other options.
Let's hope not, 'cos I'd imagine it very unlikely nvidia would sell you one.
My riser is a Gen5 one. I switched to Gen4, no dice. To get ahead of things a bit I opened up a convo with NVIDIA. They basically said they can’t, they would just replace the whole thing.
Edit: Damn just seen the video, its sent me under lol. I hope this is not the case otherwise def an RMA case
Gen 4&5 PCIE have much stricter requirements on wire length if I recall. Try pcie 3 just to test if the riser is the issue as that's much more relaxed for riser use.
I don't know if this will help, as it's not the same issue I had, but try force enabling Spread Spectrum in the bios.
This solved the issue I had on a x870 motherboard, though it was an MSI Tomahawk.
Tried this, was not working. I have too much work so I am working off the iGPU on my 9800x3d. Will probably flush tonight and try the card without the riser. If does not work in slot 1 I’ll try slot 2. This should narrow things down to either a riser issue, motherboard issue, or GPU issue.
Also my PC is switching on by itself now. Disabled the wake up on lan feature in BIOS and it still did it. Bloody thing is possessed.
In Windows, look under advanced power settings and ensure "wake timers" are disabled.
Ya done this, went into command prompt put in powercfg -waketimers and it showed me there was none. Then went device by device ensuring none had the ability to wake the PC on its own. Could be a faulty power button? Or maybe my motherboard is acting whack and could be linked to my code 99 issue too? Hard to tell
Ok so update, tested without riser cable, the GPU is not even being picked up anymore, does not get stuck on code 99. Just goes straight to desktop through the iGPU.
Just checking.. you did remember to reconnect the power cable to the GPU?
Have you tried both pcie slots? Do you have a second PC to test the card, or an old GPU to test the motherboard?
Yes of course, connected everything. Tried both slots with and without riser nothing. Unfortunately no access to a mobo or GPU as this was the first PC I built in ages coming gaming laptops. Perhaps I’ll just order a 5070 and use that to test, if that works it’s the GPU. If not then the mobo. But testing with a card will much easier and quicker.
Did you watercool the card yourself? Possibly a loose connection between the GPU boards?
Yes I did. It’s actually pretty straightforward to waterblock. No sure there is a loose connection. My gut tells me either the motherboard is done (very unlikely as it is functioning normally and both slots did not pick up GPU) or the card’s PCIe connector has somehow failed as @Tetras above shared a video where the guy in the says how fragile the connector seems.
Hey, it's worth checking, just to be sure..
Otherwise get the stock cooler back on and RMA!
Either way, you will need to take the block apart..
So it’s dead, I managed to get a hold of a 5070 temporarily and booted straight up. When in the air cooler the fans start spinning and LED comes on. So probably PCIe connector has gone. I will RMA but I might sell the replacement a get something like an Inno3D 5090 Frostbite instead.
The problem you might have now is that seeing the scummy company that is selling the FE cards in the UK and how they are not at all customer friendly they may reject the RMA as you have had the cooler off, especially if it had a sticker over one of the screws. You didn't tell them you water blocked the card did you?
