- 30 Jun 2011
- Birmingham UK
I have recently move computer rooms - now in a much smaller box room, with my PC in a pretty tight spot next to another PC under the desk fairly enclosed in.
From previous posts and question I asked I am gonna mount a 200mm fan in my desk top to draw out hot air which collects behind the PC's and also upgrade my stock fans to some that will shift almost twice the air through the case.
I was just wondering if I need to renew the thermal paste while I'm at it. Idle temps according to core temp are 50c - going to about 55c when just doing a bit of internet surfing. Under load it hits 85c. Everything was 10c lower when the PC had space.
Will the new fans cure this or do you think the problem runs beyond airflow?
