- 2 Sep 2012
Hey guys
So recently I went and posted a build thread requesting ideas on parts etc;
http://forums.overclockers.co.uk/showthread.php?t=18438300
I went with Uncle Petey's build, minus the monitors and with a different case (http://www.overclockers.co.uk/showproduct.php?prodid=CA-294-CM&groupid=2362&catid=2231&subcat= if you care
Anyway, things went smoothly with the build. Had the PC up and running for around 3 weeks now. Since I was fairly busy, I didn't really have as much time as I though I would to actually chill and play some games. I only just installed BF3 to fully test what the machine was capable of. I'm just about hitting 40-50 fps when maxed out. From what I've been told, with a build like this, I should be getting a fair bit more. I just wanted to ask what it might be that's limiting the performance, if anything at all.
I also have another problem. My (soon to be) 1-year old laptop (MSI GX660R [i7], purchased from OC) has recently started blue-screening. Heres a photo of the error that I get (Sorry for the blurriness
http://i50.tinypic.com/2wcpi5i.jpg
Any ideas what may be causing it and/or a quick and easy fix?
).Anyway, things went smoothly with the build. Had the PC up and running for around 3 weeks now. Since I was fairly busy, I didn't really have as much time as I though I would to actually chill and play some games. I only just installed BF3 to fully test what the machine was capable of. I'm just about hitting 40-50 fps when maxed out. From what I've been told, with a build like this, I should be getting a fair bit more. I just wanted to ask what it might be that's limiting the performance, if anything at all.
):http://i50.tinypic.com/2wcpi5i.jpg
