5400 RPM Time to upgrade?
28 Dec 2005
Manchester, UK
Over the past few years I've upgraded everything except my harddrive, I have just found out what type it is:
Seagate
40GB(of course I new that before :P )
Seek time of 8.9ms
5400RPM
Is it time to upgrade?
Certainly is! A modern HD can speed a system up nicely (remember it's one of the slowest parts so can make a difference).
The rotational speed of the drive has a direct impact on how fast the drive can serve up data. A 7200rpm disk will be a big plus, also a new disk will hava more effiecient cache and probably lower seek times. FYI the norm in the server world is now 15000rpm.
Sorry I should also point out the sight downside of faster disks, i.e. they draw more power and run hotter. However if your PSU is reasonable the cooling shouldn't be a problem
Don't forgot about the added noise, can be the most irritating noise coming from a PC
Most fluid bearing drives are near silent.. I would think an old 5400rpm drive will whine/grind a lot more.
alright I plan to get a new one, 120gb SATA with generaly better specs then my old one :P
Still going to keep the old one as somewhere to store music/videos and backup data and all that.
Anyone recommend a well trusted hard drive maker?
I always go for Western Digital or Seagate, as they are fast, silent and reliable. I hear good things about Samsung drives too (very quiet).
A 7200rpm 8MB cache drive will give you a very noticeable boost... if you went for a 10,000rpm Raptor it will literally blow you away :p:D
Suman
As others have said there will be a noticeable difference. When i install xp on a 160GB SATA drive it takes about 40 minutes but installing it on a 5400RPM IDE drive like i did the other day took over 2 hours. :eek: There is definitly a difference in windows too.
