5600X Help
1 Jan 2009
Northampton
Hello, I just received my sons upgrade
ASUS ROG Strix B450-F Gaming with an AMD Ryzen 5 5600X
I installed the motherboard and new CPU but it wouldn't post. Fans all spun up but no display.
I installed his old 2600 and it booted so I UPDATE the BIOS to the latest version.
Once complete I reinstalled the 5600X and now it won't even turn on. Power is going to the Motherboard but when you press the power button nothing happens. I tried shorting the jumpers and nothing.
I then reinstalled the 2600 and boots up perfect.
Any idea what's going on?
Thanks in advance
Thanks in advance
Can you check the specific version number of the BIOS?
https://rog.asus.com/motherboards/rog-strix/rog-strix-b450-f-gaming-model/helpdesk_cpu
I agree it sounds like a BIOS issue, start by making sure you downloaded and flashed to correct version.
https://rog.asus.com/support/Article/563/
