Permabanned
- 10 Nov 2005
So I was about to pull the trigger on a 2x16gb cas CAS 16-19-19-36 3600mhz Corsair Vengeance kit for £88 delivered... I know I simply enable xmp on my b550m msi mortar max wifi board and it 'should work'...
But I'd forgotten AMD states 3200mhz for compatibility?
Is there any gain when I'm not going to be overclocking the pc and infact undervolting it.
Should I just get the same kit but in 3200mhz cas 16-20-20-38 form for £64 delivered?
Will I have any issues using the 3600mhz?
This is the first rig I'll have built in like 15 years so all I've got to go on is what I've seen mixed opinions of online...
The price difference doesn't bother me, but I want this machine to be rock solid and not end up with a nasty surprise and find out it's the ram at fault!
Open to your experiences!
