5770 Trifire
The bench results for Trifire aren't too bad, the scaling performance has certainly increased lately but I honestly would never consider Trifire, maximum two cards for me :D
Looks really smart, but yeh i agree i also head that Tri Fire does not scale well, but we will see... apart from that mate, stunning...
Dirt 2 Benchmark 1680x1050 everything on max
1 card
min_fps="28.852911" av_fps="35.243622"
2 cards
min_fps="47.780144" av_fps="54.601063"
3 cards
min_fps="79.332191" av_fps="95.851524"
very impressive and good man for taking the time to bench them individualy, the more benches you can do the better matey, its getting sold to me quite quickly :)
the unigine dx11 bench scores for 2 cards are just about the same as mine with the phenom II @3.6ghz, show the i7 @ stock around the same performance as a ~3.5ghz phenom with DDR2
I tested a 5770 trifire, in the Uengine benchmark it still went to around 30 FPS in some areas using tesselation
i suppose this is when the tesselation engine is at its limit, i guess the drivers wont split the tesselation workload accross the 3 cards, shame that :(
very nice, just one thing that annoys me about tri fire or whatever, it looks like the poor card is chocking :p
Tri-fire scales very well IMHO ... can you do 1920x1080 ?
No sorry 1680x1050 is the max my monitor supports
BioShock 2 Benchmark 1680x1050 everything on max
Using Fraps walking a set route killing same number of mobs
1 Card
Min, Max, Avg
56, 154, 94.620
2 Cards
Min, Max, Avg
30, 250, 145.459
3 Cards
Min, Max, Avg
24, 337, 166.812
1 Card
Min, Max, Avg
56, 154, 94.620
2 Cards
Min, Max, Avg
30, 250, 145.459
3 Cards
Min, Max, Avg
24, 337, 166.812
gawd then surely tri or even crossfire is a waste at that resolution? unless its benchmarks your interested in, i had a single 5770 coped with most cames fine at your res
It's posted for benchmarks only, a waste on Bioshock 2 yes but not Dirt 2,
35 fps with one card to 96 fps with 3 cards.
Got to spend my hard earned money on something ;)
Don't have the room for a larger screen see image below that's all the room I have.
Id have stuck with 1 card in that, look at the minimum frames, its plummeted.
I had to turn Vertical sync off in the games settings to do the benchmark otherwise it was capped at 60 fps.
But by doing so when using crossfire it made the screen flash & break up so I am guessing that when that was happening it made the min fps drop right down.
When Vertical sync was back on game ran fine with crossfire.
So yes one card on it's own at the res with Bioshock 2 is all that is needed.
