580 Owners Overclocking (help)
30 Sep 2009
Beccles, Suffolk
Just got my 580 with Xtreme Plus
and i want to overclock it (just for benchies at the min)
What i would like is if you could post your make of 580 with your core/shader and memory overclock and also your voltage.
i.e mine is at stock
KFA2 580 + Xtreme Plus - 772/1544, 2004, 1v
this is just so i can get a general idea of what overclocks and voltages go together, then i can overclock within safe margins. (hope that makes sense)
Thankyou
edit- i will make a little table and put here for comparison
MSI Twin Frozor II 580 - 950/1900, 2200, 1.1v
This is in SLI (no idea what they do solo) and they will definitely go higher, but temps get a bit to high for my liking. I will have them both water cooled by the end of the month - once I decide on the last few items.
Palit single fan version.
My target was 900 core 1800 shader. Achieved with 1.1mv just bench marking.
TBH the card is soo good, i normally play with standard settings 772/1544 never had any issues.
tbh either bump it up too 800/1600/2000 and leave at stock voltage or go for 900/1800/2200 and it will need around 1.05v > 1.1v if your lucky... :D
