Do these scores look low?
Cinebench R20
CPU multi 5271
CPU single 491
I have BIOS defaults enabled, XMP on auto and RAM is looking correct.
MSI MEG Unify X570
BIOS is up to date (1 version behind - 7C35vA7)
https://www.msi.com/Motherboard/support/MEG-X570-UNIFY#down-bios
AMD Chipset drivers have been reinstalled. No issues with a Ryzen 5 3600 in the same board.
CPUZ bench looks ok, 651 single, 6611.4 multi
edit, there is only 1x 8 pin power (2x4 pin) to motherboard. It does have the optino of adding another 8 pin power connection but was told this is for LN2 use only
edit 2, ill start by getting the latest bios applied as have noticed this thread
https://forum-en.msi.com/index.php?...igher-than-3200mhz-with-a-ryzen-5800x.349509/
Cinebench R20
CPU multi 5271
CPU single 491
MSI MEG Unify X570
