5800x overclock info
Are you all able to pass 45min asus realbench at the set speeds?
4.7/4.75 looks to be consistent on the 5800x tbf thats impressive on all threads. I may look around for a chip myself
I haven't tried real bench but haven't had a crash with any games or benchmarks so far.
I will give it a go and see what happens.
I am really impressed with this chip, its great value and performs very well compared to the 6900K that cost me a small fortune a while ago.
By all accounts I have a golden sample... only taken me around 20 years of the silicon lottery!!
Matt
Temps are a solid 15c lower max! I'm guessing your frequency doesnt stay at 4.7 when stressing? Would explain the difference of 15Gflops in the intelburntest scores
The 15c could be down to many things. Cooler, ihs contact, open case, colder room. Hwinfo shots show the cpu is holding boost.
I kind of figure its more to do with the actual frequency dipping below 4.7 under stress - like i said would explain the why your score is 15gflops lower - what i did to check this was reset hwinfo stats, run the stress test, screenshot at the 8th test to show the average stats
Real bench run for 10 mins. No issues. Not going to run it longer as I don't see the point.
You're using a quite old version of Realbench, you should at least get the latest one.
https://www.techspot.com/downloads/7050-asus-realbench.html
Also 10min Realbench is only for really unstable overclocks, you should really run for 30min minimum for a more thorough test. I've quite often had it pass 10 mins but then give errors after ~25min.
ooh - strange im only using basic 3600 ram
If you have 3600mhz and a 1800mhz fabric clock for 1:1 ratio. You test would be a lot better than say 3600mhz with stock 1200mhz fabric clock.
But the cpu load and stress would be the same. The tests eith slower ram runs longer so the full test it still completed by the cpu
