5800X3D and B450 MSI Tomahawk Max RAM compatibility
12 Jun 2006
Hey all, doing a partial upgrade (7900XT, 5800X3D, 32GB RAM) to replace my 5700XT, 3700X and 16GB 3200 RAM.
I've already ordered GPU and CPU and instead of adding 2 more 8GB RAM sticks I'd like to replace my existing ones with 2x16GB low profile sticks as my cooler is the Noctua D14.
The RAM compatibility page on MSI's page is a mess so I thought I'd ask here just to be sure on what's my best option.
Should I aim for 3200, 3600 or it doesn't really matter? Are the Corsair LPX decent? What would you recommend? Perhaps 32GB is not needed for gaming?
It's probably worth having a look at the member's market to try and get something a bit cheaper? 3600MHz CL16 is considered the sweet spot for the Ryzen 5000 series, any higher speeds or lower latencies are a bonus if you can achieve them (depending on what infinity fabric speeds your CPU can reach to maintain a 1:1 ratio with the memory).
5800X3D don't care too much about RAM speed, I would buy some cheap 3600 C16 sticks and maybe overclock them a bit..
Hmm I can't seem to find any 3600 C16, only C18?
May be a typo and means 3200 C16 sticks, hence the overclocking bit.
Don't think it's a typo. 3200 comes in c16 and c14 variants- with c14 being the 'b-die' kits, and c16 the 'standard' stuff. Same with 3600, but c18 and c16 respectively. The lower latency is usually a bit more expensive, but arguably worth it for Ryzen. There's a bit of c17 stuff out there too, no idea about that :D
This would be my pick... https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html but it's not low-profile, so options could be more limited. The Corsair LPX will fit, and work though.
