5800X3D on the way - Alpenfohn Matterhorn good enough?
6 Oct 2004
Birmingham
Pricing seems to have dropped quite nicely on the 5800X3D, so I've just ordered one to replace my 3700X
Wondering if my cooler is going to be up to the task though, or if it's time to finally replace my 8 year old Alpenföhn Matterhorn?
Runs nice and cool and quiet at the moment, averaging in the 50s-60s maxing out about 77c after gaming for a couple of hours - how much hotter is the 5800X3D than the 3700X?
Cheers!
So a better cooler isn't going to do much since the heat won't reach it any quicker? Or am I looking at it the wrong way?
@Haggisman you are looking at it the wrong way.
a better cooler will absolutely help as it will keep the temperature differential high, so improving conduction of heat away from the chip
Makes sense, thanks :)
Any suggestions on what to look at?
Maybe something with 140mm fans to keep the noise levels down, or is it worth paying a bit more and going down the 280mm AIO route?
My case can apparently take up to 190mm high coolers, so pretty much anything goes!
Thermal right peerless assassin
Though personally I would at least try out the Matterhorn first before thinking about buying a new cooler
