5820k @ 3.8 temps on Air
21 Sep 2010
Hi guys
Received my OC UK bundle yesterday and was doing some benchmarks on the CPU
5820k @ 3.8Ghz
idle temp - 35-40 degrees
Prime 95 - 90 degrees within 5 minutes
Asus real bench - max 76 degrees over 15 minutes (however around 74 for most of it)
My cooler is Phanteks TC 12DC, Case Enthoo prime with 3 case fans.
The GPu was a cheap Geforce 210, Titan X to be installed eventually.
Is the Asus benchmark more reliable than the Prime benchmark?
I read on another forum that there is a bug with Prime 95 and Haswall-E or is that a load of BS
Is it worth running the Asus benchmark for long period of time? (4 - 8 hours)?
Or do those temps look way to hot already and I should reseat the fan with thermal paste again?
Thanks
Jim
Your fine,Prime uses AVX intruction sets which increases the Vcore above the bios settings,thats why it runs so much hotter.
Realbench is a far more realistic barometer of temps when the cpu is put under prolonged 100% usage.
Enjoy the rig!
Thanks for the feedback guys.
I did a 2 hour stress test with the Titan x next to it and the max temp was 84 degrees on CPU, however most of the time the cores where around 80 degrees. Titan was around 79-83 degrees most of that time.
However I have just moved the PC into my room and the idle temps are a lot higher now, about 4-5 degrees hotter. A 15 min stress test temps peaked at 84 degrees.
I assume gaming will be a lot less stressful on the CPU than these tests.
I will monitor it during the week, the paste job I did was not the best so I may redo that with some Artic silver.
Temps of 85C are a little high,but your never gonna stress your system anywhere near that hard in day to day use/gaming.
Keep an eye on it while you go about your regular workloads/gaming for a few days just to be sure.Maybe also increase the PWM curve on your case fans
Thanks for the feedback, had a long gaming session yesterday, approx 6 hours in Witcher 3 and max temp was 68 degrees on CPU so I am ok with that.
Will keep an on eye it over coming weeks in case it creeps up quickly.
