- 19 Aug 2009
- Cornwall
Right I've asked about this problem before but I still have found no solution.
I purchased a 5850 http://www.overclockers.co.uk/showproduct.php?prodid=GX-215-SP this one to be precise.
It worked fine for a couple months and then ramdomly started locking up and random blotches appearing on the screen.
Thinking that the GPU had failed I sent it back to OC and they said that it works fine. Tried it when it was returned to me and could hardley get any display out of it before even getting into windows.
I tried it in both PCIe slots on my mobo and have a 3450 in at the min and that works fine.
Only thing I can think of is the power supply?
Is it possible to be able to power the computer and work fine but not enough to power the 5850 as well? (the 3450 doesn't need any power cables)
Specs are: i5 1156 @2.6 ghz http://www.overclockers.co.uk/showproduct.php?prodid=CP-299-IN
4gb ripjaw ram ddr3
p55 gd65
1x500gb samsung f3
1x1.5tb samsung f2
700 w ocz psu http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-OC&groupid=701&catid=123&subcat=1098
Windows 7 64 bit professional.
I'm stumped I dont want to keep sending things to be rma'd and getting charged £20 when they work fine.
Thanks for any help.
Sam
4gb ripjaw ram ddr3
p55 gd65
1x500gb samsung f3
1x1.5tb samsung f2
Sam
