5850 overclocking problem.!
6 Apr 2011
hi i have a sapphire 5850 extream. and was delighted to hear that the new trixx supported voltage tweaking. i was hopeing to get about 850 on the core. but when i rise the voltage and overclock it is very unstable and keeps crashing i later descovered via gpuz that the voltage only hit a max of 1.088 (standered voltage) any sugestions??
Someone else will jump in im sure but I think its the ccc restricting it. You need to adjust the ini file to enable the overclock. A quick google search should help you find what i'm refering to.
*edit* that is for the msi afterburner overclocking tool
yeah thanks for the help but it didnt work i think this card can only be overclocked via the saphire trixx softwear :|
i have the exact same issue,i have fixed the gpu voltage in trix 4.0.1 to 1.93 but gpu-z is reporting the stock voltage which is 1.088 ??? is gpu-z even reliable ?
yeah i think it is reliable i am gonna reinstall a different version of ccc and try it again
