5850 - Power
3 Nov 2009
Dorset
Can anyone help me, just installing my 5850 and notice its got 2 sets of 6pin sockets for power i only have 1 of the cables that fit from my PSU, do i need both to power it what happens if not???
Yes, you do need both to power it.
Not sure how you'd go about sorting it though, have to wait for someone else. Sorry.
Cripple.
there should be some adapters in the graphics card box to convert 2 molex into 1 x 6 pin PCI-e socket, that will give you your 2nd PCI-e connector.
ive had a look all i got is a cross fire bit, cd, a vga adapter and the manual :(
guess i'll just have to buy one tomoz, wanted to have it all up n runnin wich sucks
do'h! Was it a VTX branded one? as thats the only one I've heard that doesn't come with one!
http://http//www.overclockers.co.uk/pimg/CB-018-AK_400.jpg
This is want i want right?
I found one spare in my old box trusty nvidia lolz, k the adapter has a 2 pin and a 3 pin molex that adapts to the 6pin (PCI-E) what one do i use??
