5900X for video editing/encoding?
29 Aug 2010
Cornwall
I realise that a Threadripper setup would be best for video work, but I don't do nearly enough of it to justify £2500 - £10000 on a CPU for it.
So, for a machine that will be used for occasional video editing and encoding would a 5900X be reasonable these days? I figure it's about £100 cheaper than the 5950X and maybe more if you go 2nd hand. Motherboard is around £125 and I think I have DDR4 I could use, but that's cheap now too.
How hot do 5900X run? Do you overclock 5900X or undervolt them or what and how does that affect temperatures?
My other option is to wait for the 9000 X3D chips and repurpose my 7700 (non-X). I realise it's less cores but it's newer and I think reviews suggest the 7700X isn't far off the 5900X in x264 and even ahead in x265 (not seen mention of AV1). I realise the 7700 isn't quite as good as the 7700X. Would mean a new motherboard, which currently is a little more (maybe ~£150) and some DDR5 which is ~£125? So prices are similar, except with the 5900X I'd eventually have a spare 7700, but not sure there'd be much interest in that by that time. Going with the 7700 means I'd have to wait until I upgrade my main rig.
I can't decide if the 5900X is good value or a poor investment these days as it's about to be 2 generations out-of-date.
12x zen 3 cores are pretty much the same as 8x zen 4 cores if the app scales meaningfully with cores/threads, so in terms of performance there's little in it. Single thread on the zen 4 CPUs is quite a bit higher though, so in short-term or bursty stuff the 7700/7700X will win.
Personally, I'd go AM5 and re-use your 7700, since it makes more sense to invest the newer platform, but if your use is that occasional, what's the point in offloading it to a second PC with the same performance?
yer 100% go with the 7700, you also have the added benefit of DDR5 and pcie 5.0 on the new platform that will all help with larger files
The upgrade cycle is about to kick off, MM will probably have lots of 7x chips and maybe Mobo's and RAM a bit later when the 8x chipset is released.
