- 7 Jun 2010
- valleys man
hi i recently acquired 9500x idle speed never went below 4.0 but since i flashed my motherboard to the latest firmware it now sits around 1.6 to 1.7 is this normal for 9500x
been long day loli know google searching most the night with no real answers or any one else having this problem could be the new bios firmware not sure if i can flash it back to the old firmware was working great till then i run cinebench multi core test scales up to 4.2 at 76oc when i try single stays at 1.7 at 38oc1.6ghz at idle doesn't seem right and not heard of anyone having such low idle speed.
You can flash any version with bios flashback i think , what motherboard do you have ?i know google searching most the night with no real answers or any one else having this problem could be the new bios firmware not sure if i can flash it back to the old firmware was working great till then
In advanced power options under processor power management, set minimum processor state to something lower than 100%The lowest I've seen mine drop to is 2880Mhz, and that only seems to be for a split second. It's normally at 3600MHZ when idling, and that's with every power saving feature enabled and balanced power plan
