What would you recommend for an SLI 980Ti setup? 5920k, 5930k or wait for the new Skylake?
Thanks in advance!
Thank you, I may just go for the 5920k then and save some money![]()
. Some people use their systems for more than two minute eggs
. Till someone gives me a section, sounds like a good idea!
. I won't post in this subsection again. Not even to extend on your limited comments to people.Not everyone has a huge budget.
except for OP.
OP has £1000 worth of 980TI graphics cards.
OP is considering pairing this with a £400+ CPU.
OP has not mentioned budget.
For 16x 16x SLI you need 5930K. 5820 simply does not have the PCI lanes onboard to support 16x 16x.
Although your motherboard has 2 x16 slots the 5820k only supports 28 lanes. So your second card would be x8. If you had a 5930k or above you'd get 2 x16 slots in SLI.
oh i see...
so for example i got a 2nd ti, and it ran on x8 will i not get an increase in graphics power or is there absolutely no point in going sli due to my 5820 limitation?
I have a 5820k and 980ti SLI and in games with good support you get near perfect scaling - the drop from x16 to x8 is barely perceptible even on benchmarks
you only really need a 5930k if you are planning on going 3 or 4 way GPU
8pack is a pro benchmarker, so every fraction of an fps matters, but for normal gaming useage you wouldn't notice the difference
