This has been discussed many times but is driving me crazy.
I have disabled PBO/SAM and temperatures although improved.. They're still higher then I would like.
If I have the CPU running with PBO enabled then the temperatures reach 90 degrees.
My setup is below:
Lian-Li Dynamic Midi Case
MSI Mag x570 Tomahawk mobo
T-force 8pack 3600 CL14 ram
5950x (Just purchased/fitted) - Arctic MX-4 applied
RTX 3090 FE
Deepcool castle 360 rgb v2 (seems very noisy)
Also got CF120 Plus case fans x 3
I have taken a screen shot of HWinfo to give an idea of temperatures whilst running CinebenchR23 (PBO disabled)
and temperatures when running warzone/vanguard (PBO still disabled).
I dare not run a game/benchmark anymore with PBO enabled though on the Cinebench tests when PBO is enabled I get 28k multi core score compared to 24.5k with PBO disabled.
I have CPU cooler fans PWM setup with a push/pull config (case fans pulling air in and top mounted AIO pulling heat out).
AIO pump is in correct slot..
I'm completely at a loss as to what is causing it. It's also hugely disappointing to hear how noisy my pc is trying to keep things cool. the AIO is meant to be 30db or less but can hear the fans working hard from a couple of rooms away in the house.
I've also attempted a lower fan curve in bios but obviously lower settings mean more heat.. A more aggressive fan curve will make this thing sound like a rocket ship.
HELP!
My setup is below:
RTX 3090 FE
HELP!
