Good afternoon, I've recently purchased a 5960k, gigabyte x99 Ud4, 16gb of team dark 3000mhz ram it's currently in a watercooled loop just for the CPU.
After hours on prime my hottest core was 55 degrees so I'm deciding to overclock it nothing major but I was wondering if you had the rough settings for me 8 pack just to get to say 4.2 if something higher is easily achievable that'd be great.
Any sort of input would be fantastic.
, Open core temp and just use your PC as you would and regularly check the temperatures
