Yes ring voltage
Yep mems can be sensitive, 1.05v SA is a good starting point for 2666mhz
Done everything you said and still not stable. This is really doing my head in ..still can't get it stable even using just aida64 stress test crashes after 8 mins and my cores are at 61c max at 4.5ghz with your settings and 1.35v. Now whocrashed is saying thermal issue ..what thermal issues ?..The crash before the 4.5ghz was at my settings of 4.375ghz and ram 3000 mhz xmp. 1.30v
then tried 2666mhz with your input and 43ghz ..and my max temps was 56c .the setings of ram at 2133mhz default without xmp and strap at 100MHz 1.35v
longe
On Wed 13/01/2016 18:28:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011316-9859-01.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0xCF)
Bugcheck code: 0x124 (0x0, 0xFFFFE000618AC028, 0xBF800000, 0x124)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
On Wed 13/01/2016 17:57:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011316-9843-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE001F7EE2028, 0xBF800000, 0x124)
On Wed 13/01/2016 17:35:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011316-9718-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFE000676E1028, 0xBF800000, 0x124)
On Wed 13/01/2016 03:55:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011316-9515-01.dmp
This was probably caused by the following module: hal.dll (hal!HalPutScatterGatherListV3+0xD1AB)
Bugcheck code: 0xC5 (0x100000000, 0x2, 0x0, 0xFFFFF800C3E48840)
Error: DRIVER_CORRUPTED_EXPOOL
Bug check description: This indicates that the system attempted to access invalid memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Wed 13/01/2016 03:50:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011316-9375-01.dmp
This was probably caused by the following module: cpuz138_x64.sys (cpuz138_x64+0x2084)
Bugcheck code: 0xA (0x14E748, 0xF, 0x1, 0xFFFFF801EB5F5197)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: cpuz138_x64.sys .
Google query: cpuz138_x64.sys IRQL_NOT_LESS_OR_EQUAL
