5960x Question
@Jacky60
I have looked through the bios and I can't for the life of me find the setting to keep the memory jumping to 3333mhz instead of staying on 2666 at least when XMP is on with 125 instead of 100. I tried manually dialing it in but no luck so may have to leave my memory.
I wonder if @koooowweeee might know or @~>Dg<~ ? Need to work this out guys. You can see my mobo screenshots on earlier post.
I would use the XMP settings from photo without setting XMP. We may be flogging a dead horse here as IMC needs to be good maybe try with just 4x4gb sticks in quad channel that will at least prove its not all slots populated as an issue.
Yeah I already use those settings mate, he doesn't use XMP same as me. Weird that I can't touch xmp.
Well I'd try XMP at stock settings with all your ram sticks in place i.e. 3000Mhz core clock or whatever it is because your memory should be able to run at stock XMP then I'd go from there. Alternatively I might just not bother;)! Good luck either way.
Yeah I can use XMP mate and have done in the past but when the overclock gets so high I can no longer touch it. Think it worked upto about 4.1ghz or something, no good to me. It's alright no loss really, it doesn't affect gaming.
