5970 3 displays - help?
31 Dec 2009
I have a Saphire OC 5970. I have 3 displays. A Samsumg LCD connected via DVI, an older monitor AVG->DVI, and a TV connected via HDMI->Mini Display port.
I am trying to extend my desktop across all 3, but running into problems.
I can get any 2 working fine, but when I try and extend to the 3rd one the ATI Catalyst warns me that it needs to disable an adapter to do this.
So, am I trying to do something that is impossible, or should there be a way to do this with a single 5970? I thought that with this Eyefinity thingamajig 3 displays was feasible, or is that just within games?
Thanks in advance.
Thanks for the replies.
So is that Adapter you linked a necessity for 3 way windows desktop extension (i.e I can't possibly achieve what I want without it) ? From the info on the item page it does kind of sound that way, but I just want to make sure I can't do it without, before splashing out;)
I am currently using the Mini Display port to output to my TV via an HDMI lead.
I don't understand why I cannot then use the 2 DVI connections to output to 2 monitors, without needing to buy an extra (£80 :eek:) adapter.
cheers
