5970 power supply
Will be fine with a single 5970, the 750HX would probably run two 5970s with your system if everything was at stock (might be pushing it tho).
If the power supply was not quite enough would it cause any damage to the gpu or would a quality psu like one from Corsair switch off and protect the components before that happens?
Depending how much other stuff you're planning to put in, as Raven said, go for the 850
