5970 Woes ?
If there is suspicion that the psu is not upto the task oc'ing his cpu might not help and might cause more problems. I would wait the couple of days till you get your new psu and can then definately rule that out. Personally i would say the drivers are flaky and maybe wait till the next set come out and see if there is any improvement. Not very helpful for you m8 but all i got right now :).
You're very kind, sir, like the rest of the people here.
It's more noticeable when a pop-up like friends joining steam occurs, the screen just flickers/stutters.....
Flakey drivers... I suspect something in windows too....
When I grab a web page and hit the top of the screen, like it wants to expand itself, the flicker/stutter happens too....
And scrolling up and down too.......
Something like a Corsair TX if you don't mind non modular will provide nice clean power to a card like this, something 750w+ above they are great value as well!
HD Ati Audio disabled my SupremeFX X-FI card as well.
Disabling the device brought the x-fi card back after reboot.
Its always phun at the bleeding edge :)
Normal that, ATi always default to Primary, just switch them over in control panel
Did you do a fresh install of windows i know you shouldn't have too and it's a pain in the behind but in the past has solved the odd problem for me. After you have done a clean install and if you have the hd space to do it clone the fresh install to a backup partition and you can get it over with more quickly in future i use acronis disk director to do mine but i am sure there are better programs around now to do it. Worth a go if nothing else.
I have now uninstalled the current beta's from amd's site as I was starting to have issues with windows stability.
Back on the Sapphire CD drivers and it seems a lot happier.
My jeantech PSU (700W modular) is great, ive never heard of any problems with them :confused:
no disrespect but jeantech from my experience are crap they were nearly as bad as qtec in the past and they were bad so maybe they have improved, the most common thing peope seem to skimp on is a psu yet its possibly the most important par.........
Got to be a driver problem that, if yer just browsing the web the cards only supping about 40w, no way would it be sucking to much power doing that to make the screen flicker lol.
If his PSU cant handle browsing the net, then when he starts a game, his PC must just gan BOOM!!!! :D
Are the memory clocks changing when the flicker occurs?
EDIT: Multi monitor has never been ATI's strong point so I wouldn't be suprised if its a driver issue.
look who posted it ;)
Considering this is Nvidia, who simply refused to let home users use many of the dual monitor features because they reserved it for business cards only, for a couple years I can't remotely take any criticism of Ati's dual monitor's seriously considerings something they've supported far more widely for far longer than Nvidia.
Two things to try, disable crossfire using the Catalyst AI set to default, should disable it anyway. Do this also from a fresh boot, as soon as you get to the desktop open Gpu Clock tool and change the clocks to the default 3d clocks( 725/1000 iirc) and press the set clocks button. Use GPU-Z to watch the current speeds, GPU clock tool should(till a reboot) disable powerplay and stop any clocks from dropping.
Is the second monitor still flicking around like a git when you've done that. For me and several other 5850/70 users powerplay is playing havok at the moment, with some peoples problems being fixed by mobo bios updates.
For me several small but irritating problems were fixed by disabling powerplay, and while I do like the uber low idle power usage, being at overclocked speeds all the time doesn't actually raise the idle power usage by that much so till new drivers fix it I'm happy to do so.
It will be a bit more difficult because I'm not sure if GPU clock tool can fix powerplay on both cores or not.
try it with one disabled anyway, if it fixes the flickering try to set both cores clocks(in gpu clock tool you should be able to bring down a list of the cores at the top, change to the other core and set the other to the same clock). Hopefully that could fix it, powerplay being stopped fixed my problems with dual monitors and flickering aswell as a couple other issues.
It seems perfect timing with powerplay is dropped in speed isn't being handled perfectly at the moment.
The other option you have, if of course your main display as a dvi port aswell, is to run both monitors on DVI as it might be an issue with various timing of different connection types, its worth trying various setups though.
Well my jeantech has powered 3 systems since ive had it and has put a foot wrong on any of them and my current system is exactly what you would call eco friendly.
i7 920 C0 3.8ghz
6gb corsair dominator
nvidia gtx 285.
However my next PSU will definatly be a corsair ;)
Here's a 700W Jeantech spec.
Model JNP-700-A12C
VOLTAGE 115V - 230V
FREQUENCY 47-63Hz
CURRENT 10A
EFFICIENCY 80%
P.F. 0.99
+3.3V 28A
+5V 0.5A/30A
+12V RAIL 1 1A/16A
+12V RAIL 2 1A/25A
+12V RAIL 3 1A/17A
-12V 0A/0.5A
+5Vsb 0.1a/2.5a
+3.3v & +5v 180watt
Total output 700watts
What does that tell you? No combined 12v current for a start, not good. Oh and the web site refers to the 700W as maximum power, again not good. Sustained or continuous power would be the preferred value.
700w - 180w (combined 3.3V/5V) - 12.5w (Vsb) - 6W (-12V rail) = 501w
or 42A@12v and that's probably a PEAK figure.
