5m USB 2.0 extension cable problem.
25 May 2010
I just picked up a 5m USB 2.0 extension cable to use with a pc xbox controller and I am having problems. Once I plug it in it's not stable and keeps turning it's self off and on every few seconds.
The controller is fine if I plug it directly into the pc and the cable is fine when I connect other devices like an MP3 player.
Any idea as to what's going wrong?
Thanks
The confusing thing is that the cable works with other devices like my MP3 player that draws power to recharge from the USB port. I was just wondering if there is something special about running a controller over an extension maybe?
Ok my bad, I have just realised that the on and off sound that I am hearing when I plug the controller in is for my keyboard (sidewinder x4).
If I use the cable the it turns the power on and off on my keyboard. The keyboard is backlit so I tried with the back light off in case it was somehow a power draw problem and it made no difference??
I have a powered usb hub somewhere, maybe I will give that a shot.
