6.0.1 Released.
19 Oct 2005
Kernow
This update contains improvements and bug fixes, including:
- Fixes a bug that prevents iPhone 5 from installing software updates wirelessly over the air
- Fixes a bug where horizontal lines may be displayed across the keyboard
- Fixes an issue that could cause camera flash to not go off
- Improves reliability of iPhone 5 and iPod touch (5th generation) when connected to encrypted WPA2 Wi-Fi networks
- Resolves an issue that prevents iPhone from using the cellular network in some instances
- Consolidated the Use Cellular Data switch for iTunes Match
- Fixes a Passcode Lock bug which sometimes allowed access to Passbook pass details from lock screen
- Fixes a bug affecting Exchange meetings
Just tried to update but now restoring due to my phone being stuck in DFU Restore mode and no combinations of home and lock button exiting it...
Annoying...lucky i had a backup just before.
Do you restore after?
I'm on a iPhone 4 restore originally on the 5 and was always tempted to go for a fresh. Is app save data saved to the app or user?
My finger just slipped on the order button for a iphone 5 (:D). I see there isn't anything mentioned about maps in the changelog, but has there been any improvement to maps since release?
I think its just incremental changes that happen over time, I'm sure I read somewhere (maybe verge) that users could submit error reports on locations and stuff. Maps & locations are downloaded from a server aren't they so it'll be updated continuously.
Updating now. A quick question for you guys, without the update, are you guys getting issues with the volume settings for "New Mail"? If you go to Sound > New Mail, and change the settings in there, then you go to Notifications > Mail > New Mail Sound, you find they aren't the same (they appear to be separate). Unless I'm missing something, surely this is a bug?
6.1 beta is available for developers now.
Map Kit Searches
The Map Kit framework now lets you programmatically search for map-based addresses and points of interest. The MKLocalSearch class initiates a search for map-based content using a natural language string. In other words, you can enter placename information or portions of an address and have Map Kit return search results that match the information you provide. For example, searching for the string “coffee” would return the location of local coffee bars along with information about each one.
Has anyone experienced the bug on 6.0, where you unlock the phone and the brightness appears at the lowest setting?
I have mine set to maximum brightness with the proximity sensor off, but a few times I've unlocked the handset and it sets itself to the lowest setting. I have to go and adjust the brightness to get it to "remember" where it was. Weirdly, when it happens the slider shows as being on maximum but the screen is clearly on minimum brightness :/
I hope 6.0.1 fixes this.
Happens to me. I just put the phone back on standby by pressing the top button then press the home key again and it sorts itself out.
Ive had it happen 3 times now
