60GB or 120GB
10 Nov 2011
Telford
I'm looking at replacing the 32GB SSD in my Iconia tab to an OCZ nocti either the 60Gb or 120GB.
I have ordered a 64GB Sandick SDXC card for it as well.
Do you think I will need the extra space of the 120GB driver or not?
http://www.overclockers.co.uk/showproduct.php?prodid=HD-087-OC&groupid=701&catid=2104&subcat=2365
http://www.overclockers.co.uk/showproduct.php?prodid=HD-088-OC&groupid=701&catid=2104&subcat=2365
Currently running windows 8 on teh tab as well if that make any difference on opinions?
Only yourself is really going know how much space you need...
But one thing i would say..
Is always go for a bigger drive then what you think you will need as it is much better to have to much space then to little....;)
