Im planning a small upgrade:
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Intel Core 2 Duo E6320 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard
I was wondering if it is worth spending the extra £30 for the higher multi on the e6600? Or will the spec above be good enough to max out the e6320? They will both be under water, so temperatures is not an issue.
Thank you
Alex
Edit: Bad Maths its £30 more
Thank you
Alex
