64bit Compatible Wireless Card
23 Feb 2003
Newport - S Wales
Just put a 64bit Athlon together, running XP 64. The old Dlink card I had has no compatible drivers, so I have decided to purchase a new wireless PCI card.
Can anyone recomend a card that is compatible with XP64, and ideally has an Atheros chipset? (Not a major issue though)
Thanks
I dont use wireless, but would be interested in knowing whats available for 64bit ;)
Drivers for Atheros based cards are thin on the ground at the moment. You also have to be careful as the chipset used on a model of card can also depend on the revision number of it. However there are some about for the following :
D-Link DWL-G520
Drivers : http://america.giga-byte.com/Communication/FileList/Driver/64bit_wlan42052bin.zip
Netgear WG511T
Drivers : People over at PlanetAMD64 have confirmed the the above driver will also work with this card.
*It's a generic Atheros driver so should work with any Atheros chipset based card..theory has it.
Remember to check that it's got the Atheros chipset.
For other cards/chipset drivers combos take a look in this thread :
http://www.planetamd64.com/index.php?showforum=17
Dave L said:
Do you HAVE to go wireless?
Until the new house is Cat5'd, yes!
Thanks for the driver links. I'm currently running a 520, but I think it must be an old revision, as it doesn't like the drivers at all!
